OT
- Jensen, UT
It needs no power. It is only a switch. When the air pressure drops below a set psi, it turns on. When the pressure builds up to a set psi, it turns off. This is a cycle.diabloxj said:how did you power it? don't they need 110 to run?
You will run a 12volt source into the pressure switch and run a wire out to your compressor. When the switch senses low pressure, it completes a circuit and powers up the compressor clutch.
If you look closely at my pictures, you can see a wire loom coming out of the switch. It's going to my compressor.
