Osmosisfrank
- Salt Lake City, UT
The final problem to deal with on my '99 is surge and hesitation under acceleration. I've read some threads on the forum, but haven't had any luck yet.
At WOT, generally between 3,000 to 4,000 RPMs, the Jeep seems to cut ignition til it drops to 3k, then picks up til it hits 4k, then repeats. I can hit a max speed of 65 MPH. The problem persists whether the engine is cold or has been running for 20 minutes and is at operating temp. Last night I tried disconnecting the oxygen sensor right after the catalytic converter. No difference. My guess is that it's either the throttle position sensor, or, more likely, the cam position sensor. This is all based on what I have read here on :
Has anyone else had this problem, or can anyone help me diagnose it? I think a TPS is around $30, and the CPS is more because you have to replace the whole distributor? As always, any guidance would be greatly appreciated!!!
Frank
Frank
