96XJCLASSIC
- Hollidaysburg, PA
I just bought a 99 XJ sport with the infinity system only to discover the front door speakers didn't work. The passenger side will work occasionally but the drivers side won't work at all.
I removed the drivers side door panel and found a el-cheapo speaker instead of the stock "infinity" speaker. This speaker was blown, so I replaced it with an phoenix gold speaker. There was a + and - wiring in the door to hook up the speaker and also a jumper wire with a ring connector from the factory negative wiring that was grounded behind one of the speaker mounting screws. I hooked everything up and everything worked great. Turned the jeep off and back on and the front stopped working again. I removed the ground and reinstalled it and it works again.
However, everytime I shut off the jeep and turn it back on I need to unhook the ground and rehook it up to get the speakers to work again.
What gives? Suggestions?
