Can I change this out by hand..seems pretty straightforward.Pull the front shaft and the yoke...do I need a Impact gun or will a Breaker bar work?The seal looks wet and it's only like 5 bucks to replace.
D30 Pinion Seal Replacement
Here’s the right way to do this so you don’t end up with too much bearing preload that will cause excessive bearing/race wear:
Block the rear wheels.
Raise the front end high and use good jack stands.
Remove the front wheels/rotors/calipers
Mark the drive shaft and yoke so you can put it back the same way
Remove the drive shaft
Rotate the yoke 3-4 times
Measure the amount of force needed to rotate it by using an inch pound torque wrench
Write down the amount
I use an impact to remove the pinion nut and washer
Remove the old seal with a seal remover tool or a slide hammer with a screw end
I clean the spines on the pinion and in the yoke and lube them with wheel bearing grease
I coat the new seal lip with wheel bearing grease
I use a light coating of black RTV on the metal lip (probably not necessary)
Install the new seal carefully (you can easily damage these during the install)
Install the yoke and washer
I tap the yoke lightly with a small deadblow hammer to seat it on the shaft
Install a “new” nut and washer on the pinion gear
Tighten the nut just enough to take out all the end play of the pinion gear
Tighten the nut to 160ft/lbs.
Rotate the yoke/pinion gear with your inch-pound torque wrench, check the reading
If the amount is lower, tighten the nut in 5 inch pound increments till you get there plus 5in/lbs.
Put it all back together
If all this seems a bit much, you can do like some guys and just run the pinion nut down to a point where all of the end play is gone which is usually between 160-200ft/lbs. and hope there isn’t too much bearing preload. Personally I would never do it this way on newer gears or a low mileage vehicle.
My advice, for what it’s worth, is if it’s just seeping a little is to leave it alone and watch it rather than risk the possibility of wrecking your pinion bearings/races.
I hope you torqued your “new” hub assembly axle nut to 175tf/lbs. Again, preload is very important.
