Will a 99 power steering pump work on a 92 already changed the intake over to the horseshoe just want to check before I go pull one from the wreaker thanks
PS pump bolt pattern to the intake changed in 96. If you already have 99+ intake, then 99 pump will work fine. You need the whole tensioner bracketry too, which you should already have
