Ranger Rick
- S-lomita Cal
Parting my 99 Classic out, have everything including lots of premium aftermarket parts that have less than 2 years use. I would entertain an offer on the entire XJ but there is no transmission, transfer case or axles under the vehicle. I have all the parts to build a nice crawler if you read below. I have other priorities and need the room in my driveway. Body is straight, it has 169K, still has current registration through June 2016. Passed smog in 2014. Salvage title from prior owner. Nice clean forest green paint except hood has clearcoat peel & fenders are different color. Has the tan & black interior. No rips in seats, headliner is not falling & has almost all options available except: leather, heated seats & power factory sunroof. A/C needs condenser coil, all air bags are there never deployed. Has the deluxe eq CD/Tape/AM-FM factory stereo with 10 speaker infinity sound system and under seat amplifier. Loaded with all power and options most didn't have including compas/thermo/trip computer in roof console. Minor ding on rear hatch, straight body, all stock fender flairs still installed.
Come see the Jeep and make me a reasonable $ offer on the whole thing, a great start for your late model build, 1999 year arguably one of the best for a builder.
OR......
Any interior part $ make reasonable offer
Any body or exterior part $ reasonable offer
A list of some of the performance parts:
Front D44 SJ axle, Solid cover, 5.13 gears, spool, CTM's, 30 spl Chromo shafts, Crossover high steering and arms, Heims, 5x5.5 bolt pattern outers, premium 1/4 turn hubs, Synergy 3 link brackets, XJ width $1850
New in the box ARB air locker, This is the current re-designed new version and has never been installed, was going to go into the above axle, $800
D60 rear, 5.13's RuffStuff cover & shave kit (clearance of a 44) disc brakes, parking brake, Chromo 35 spline shafts high mounted shock tabs, Detroit locker 5x5.5 bolt pattern, narrowed to bolt right into any XJ Cherokee $1650
NVG-241OR Rock Track 4:1 transfer case from a 2004 Rubicon, ready to bolt into a Cherokee XJ behind any 23 spline output 4x4 transmission (hard to find TC only 4 years production) $1500
Smittybuilt SRC swing-out rear tire carrier bumper system, only mounted for less than a year, very stout includes quarter panel armor $475
Olympic Stinger model rock bumper for winch with extra long frame horn mounts to stiffen steering box area $300
Hooligans drip rail pinch seam 52" Cree LED light bar mounts 1/4" steel construction, NEW, unpainted, see Hooligans website for details, no logo version $100
Synergy 3 link long arm lift kit including all NEW brackets never mounted or painted, Track bar, track bar bracket and frame tie-in kit, front 3 or 4 link frame mounts, rear spring box up-armored mounts, already built & welded long arms (used on last XJ), Skyjacker 6-7" front springs with jounce bumper bump-stop inserts inside, Rubicon Express 5.5" full leaf spring packs (used on last XJ) & Synergy heavy duty shackles, NEW weld on sway bar extension brackets, to go with. $800
New in box, never used Rubicon Express premium swaybar disconnects $120
Set of 5 32x9.5x15 SuperSwamper LTB bias ply tires 99% tread, spare is 50% tread, mounted on genuine USA made Rockwell International Keystone steelies painted blackout 15x8 5x5.5 bolt pattern rims, some plugs in tires, no leaks, nitrogen filled. $650 the set
Set of 5 33x12.5x15 Goodyear MT/R Kevlar's 50% tread on ProComp Street-Lock 5x5.5 bolt pattern D hole simulated lock ring black steelies, rock rash & some rust but hold air perfectly $650
Lots more....
Text is best to get hold of me but you can message here also. 3Ten fiver 6 seventeseven & 24.
Thanks for reading,
Rick
OR......
Lots more....
Thanks for reading,
Rick
