HeliDriver
- Mesa, AZ
<B>
Well this is pretty weird... I finally broke down & replaced the in tank 'fuel module' because of a faulty check valve (& pressure was a little low (5psi). After going through the major pain of getting the old one out, and the new one back in (plus skid plate), it fired up & showed 49 psi, which is right on the money - and pressure holds after shutting it off. BUT ... after about 15 seconds of running there's a loud knocking coming from underneath that sounds like a piece of sheet metal rattling against the exhaust pipe, or something similar - but it's coming from the fuel tank ! I can get underneath it & actually feel the knocking coming from the tank, and it's LOUD - loud enough to hear over the engine running.
I called the manufacturer of the pump - they have a tech support line - and they've never heard of this. He just said 'you'll have to take it out again & check it'......
I'm thinking maybe it's some kind of air lock situation, as I've read about this problem with other vehicles . . . taking off the filler cap makes no difference.
Looks like I'm going to be tearing it out again I guess
. . . any ... ideas ???
</B>I called the manufacturer of the pump - they have a tech support line - and they've never heard of this. He just said 'you'll have to take it out again & check it'......
![aagh.gif](/proxy.php?image=http%3A%2F%2Fwww.virtualjeepclub.com%2Fimages%2Fsmilies%2Faagh.gif&hash=91567666e476316f3f15fe33a9c38a42)
![mad.gif](/proxy.php?image=http%3A%2F%2Fwww.virtualjeepclub.com%2Fimages%2Fsmilies%2Fmad.gif&hash=fa9d2f4bf6ce9977549dea972952ddef)
