98 XJ Limited
Ghost
Member Number 257
Camden, SC
Brought this home yesterday!
98 Limited Moss Green Pearl Gray Leather with Up Country package. Really stoked to get this. Thanks to Tim and Nick for giving it the once over with me and helping drive it back to the shop. So far I know it needs a rear hatch, front shocks, the master window switch is not working right, the power seat does not like to go foward, rear wiper is not working right, Tim says the heater core is going to go on it, and needs a new negative battery terminal. 233K miles. Does anyone know if the upcountry used a different shock with different lengths?
Thanks doug... Fixed the hood not closeing right....
The heater core is already going. That was evident by the smell of coolant and the fogged up window when I turned the heat on.
It's in need of new shocks....bad. Drove more like an old Cadillac than a Jeep yesterday...lol
I have a hatch same color, $100
Those shocks are terrifying from the passenger seat.
Is Doug coming this way for some parts? You woudl not happen to have an interior passanger door panel for a limited would you? It needs that too.
There was a battery post that had a bolt sticking up on it. I just swapped the battery terminal for now.
Contacted Jeep about a build sheet and got this back:
*DL Prem Leather Trimmed Bucket Seats
-C3 Mist Gray
ADAP Light Group
ADLP Skid Plate Group
AHT Trailer Tow Group
APAS Monotone Paint
ARTP Classic Decor Group
ASTP Limited Group
AWE Up Country Suspension Group
AWHP Power Equipment Group
A20P 4.0L Engine(ERH)/4Sp Auto Trans(DGS
BAUS 117 Amp Alternator
BCDS 500 Amp Maintenance Free Battery
BGAS Power Front Disc/Rear Drum Brakes
CACP Low Back Bucket Seats
CBZP Prem Vinyl Door Trim w/Map Pocket
CDBS Reclining Front Seats
CFMS Rear Folding Seat
CGGS Traveling Inboard Seat Belt Buckle
CGWS Next Generation Front Air Bags**
CKAS Carpets - Floor and Cargo Area
CKNS Cargo Compartment Carpet
CKTS Cargo Tie Down Loops
CKXS Midgate Box Access
CLEP Front & Rear Floor Mats
CSAP Spare Tire Cover
CSCP Cargo Compartment Cover
CSRS Passenger Assist Handles
CSSS Illuminated Rear Assist Handles
CUFS Full Length Floor Console
CUNP Overhead Console
DGB All 4-Speed Automatic Transmissions
DGSS 4-Speed Automatic AW4 Transmission
DHAP Lock-Up Torque Converter
DHPP Selec-Trac Full Time 4WD System
DHSP Floor Mount Automatic Shift Lever
DJHS 230MM Front Axle
DMDP 3.55 Rear Axle Ratio
DRAS Corporate 8.25 Rear Axle
DSAP Anti-Spin Differential Rear Axle
EAAC All Engines
ERH 4.0L I6 Power Tech Engine
GALP Deep Tint Sunscreen Glass
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEEP Deep Tint Sunscreen Liftgate Glass
GFAP Rear Window Defroster
GNAS Rear View Day/Night Mirror
GNCP Sun Visors w/Illum Vanity Mirrors
GTZP Manual Remote Mirrors
GVBC All Vehicles W/Power Mirrors
GXMP Remote Keyless Entry
HAAP Air Conditioning
HGDS Deluxe Insulation Group
JAYP Instrument Cluster w/Tach
JBGP Instrument Panel Woodgrain Bezel
JCDS 100 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBP Rear Window Wiper/Washer
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
JPSP Power 6-Way Driver Seat
LAJS Headlamps On Warning Chimes
LBBP Courtesy Lamps
LBCS Glove Box Lamp
LDAP Underhood Lamp
LDBP Cargo Compartment Lamp
LHDP Headlamp Off Time Delay
LMAS Halogen Headlamps
LPSS CHMSL Lamp
MBPP Body Color Front Bumper
MBQP Body Color Rear Bumper w/Step Pads
MCAS Rear Body Color Applique
MDA Front License Plate Bracket
MFKP Body Color Grille
MHAS Black Windshield Moldings
MMCS Rear Qtr Solid Window Insert
MMGS Belt Moldings
MMKS Hi Black Gloss/Black Mirror Molding
MNAS Black Door Handles
MWGP Roof Rack
NAA Federal Emissions
NBKS EVAP Control System
NFAS 20 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
PJN Moss Green Pearl Coat
QJNS Moss Green Pearl Coat
RAAC All Radio Equipped Vehicles
RAZ AM/FM Cassette Compact Disc Radio
RCRP 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCGP Leather Wrapped Steering Wheel
SDUP Heavy Duty Suspension w/Gas Shocks
SHAS Front Stabilizer Bar
SH8P Delete Rear Stabilizer Bar
SUAP Tilt Steering Column
TBBP Full Size Spare Tire
TBLS Inside Mounted Spare Tire
TRLP P225/75R15 Wrangler RT/S AT Tires
TZAP Goodyear Brand Tires
WJ7P 15X7.0 Luxury Aluminum Wheels
WKBP Matching Spare Wheel
WLZC All Aluminum Wheels
XCYS Delete Remote Start System
XEAP Tow Hooks
XEEP Fuel Tank Skid Plate Shield
XEFP Transfer Case Skid Plate Shield
XEUP Front Suspension Skid Plate
XJFS Tethered Fuel Filler Cap
YAAS Build To U.S. Mkt. Specifications
Wish mine was that easy..lol
Thought that was my issue..removed the whole batter just to see if it would close right.. nope. Thinking its the latch on that side of the hood.
So 10"of lift, 4.88's and 36's for the crawl right?
You got 5 months...get to working!!
No sir. This one stays like this. Fix a few things and new tires is about it. DD for my 14 year old twins when they turn 16 in 1.5 years is what I'm thinking. It will likely take me that long to fix everything! :)
Holy CRAP! They're 14 already? It doesn't seem like it's been thatlong since I've seen you guys!
Good plan though. My 10 year old wants a CJ5. No way he's getting the 78 with the V8 so i gotta find one with the old 4 bngr! LOL
