98 XJ Alignment question
bonzel
kansas city
was wondering, I plan to get an adj. trackbar and control arms.... should I try to get them and get em on before I get new tires and alignment??? Would it be fine just to get the tires and alignment & add those parts a little later??? thanks a bunch
id put everything on first and do a driveway alignment to drive it to a reputable shop that specializes in lifted vehicles as they will take care of everything beyond toe in/out (pinion angle, etc..). at least mine did. it was $30 well spent for the piece of mind.
When replacing control arms, I've had the Jeeps raise as much as 1/2" which will affect the alignment. Most likely due to worn out busings.
I usually do alignments myself, but can understand if you are getting a new set of tires.
