outlander
- Columbus,Ohio
Hey guys I need help with my DD.
3.1 litre 98 lumina .
The idle is rough and performance has suffered....shows a code for cylinder #1 misfire.Also seems like fuel economy is down also.
soooo.......
I replaced the ignition control module and #1 coil pack with units I got from the junkyard that tested good by the local parts drone.Also verified that fuel pressure was to spec.Plugs and wires changed also.
Still runs the same.
What else would cause this thing to have this problem?Stuck open injector?(wouldn't that cause the fuel pressure to be low?)I pulled number one plug and it was damp while the others had a nice gray color to them.......
soooo.......
