it should bolt up fine all the holes are in the same place.
you will need nut strips if yours did not come with a hitch, you can take his drivers side nut strip but his passenger side strip is what his exhaust mount is attached to so he'll need to keep that one. JCR offroad sells nice ones (and they are a vendor too) or you can get some cheapo ones from crown automotive from places like amazon.com or quadratec.
I dont think it will fit unless the holes are ovaled side to side. I believe the width of the frame rails was increased in 97 to match that of the GC. I tried fitting up a 97 gas tank skid to my 92 once (uses the same bolt holes as the hitch) and it was too wide.
Take some careful measurements, it may fit but my recollection is that there was a differnce in frame rail width at the rear. Hopefully someone who has actually tried the hitch swap will post up.
