alex22
- CT: waterbury area
1997 VW TDI with 330K miles on the clock... Barley broken in with a jump start it will fire right up. I picked it up off of the original owner. The car could probably be turned into a daily driver if you don't mind the look or smell of a "B4" style passat (every one i've ever been around smells the same,) but this would be better suited for someone looking to do a TDI swap. I have the title, $800 and trailer it away.
Snap-on YA 212 IND MIG/ lift TIG welder, 220 volt input, 230 welding amps at 60% duty cycle, a big welder. It has a 20 foot 10 gauge power cable, most of a 11 lb. spool of .035, misc consumables and flow regulator, no bottle. This uses standard Tweco style parts so they are also easy to get. It's setup and working if want to try it out. $650
Both are in Bethlehem, CT
~Alex
~Alex
