The change was in 98+. Yes, you will likely through a check engine code when the TCU senses the transmission is in the wrong gear, as it compares the input and output speeds.
There are three solenoids.
Shift Solenoid A, pin 12, white
Shift Solenoid B, pin 13, orange/white
T/C Lockup Solenoid, pin 11, darkblue/white
1st Gear, Solenoid A powered
2nd gear, Solenoids A&B powered
3rd gear, Solenoid B powered
4th gear, neither solenoid powered
