97+ 5-speed swap
mcguyver_xj
Grandby, MA
-got a 5-speed swap for sale out of a 1997 4x4....parts you will receive:
4x4 external slave ax15 with no grinds went in all gears, front and rear driveshafts, good clutch disc/ flywheel/ pressure plate all worked and have good life left, brand new in box pilot bearing and bushing sleeve, brand new in box throwout bearing, 4x4 shift linkage, inner and outer shift boot and shifter, floor plate, pedal assembly, crossmember and tranny mounting plate, engine to tranny dust shield, ecm, wiring harnesses so it will look factory (can be done without by jumping two wires on the nss connector but this way you have a clutch switch and stuff), all necessary nuts and bolts...
all parts located in feeding hills, ma aka agawam, ma asking $600 for everything
if help is needed i did a swap on my old 99 xj without the harnesses and sold another 5-speed swap to a friend recently with harnesses....this stuff could work for a 2000-2001 xj you wouldnt be able to use the harnesses or ecm
