DJcrawler13
- Claremont NH
the jeep is a 96 XJ, on Goodyear Wranglers 33/12.50R15 set of 5 with about 3/4 tread,
Rubicon Express 3.5" Super-Flex comes with, front coil springs, rear leaf springs, front bump stops, rear stainless steel brake lines, rear U-bolts, front sway bar disconnects, front lower super-flex control arms
Rock-It parts max-flow cool intake, custom bored out throttle body, full engine & transmission skid plate, daystar polyurethane motor mounts & transmission mount, DynoMax super turbo cat back exhaust
A new ! warn 8000 wench
custom made heavy duty front and rear bumper, as well as custom rocker panels with 6 grade 8 bolt and welded very ! ! nice and heavy duty, cut fenders all around
all new floor panels front and rear
it is pretty bare bones no back seat at all or rear seat belts this is just a offroading rid,
im getting rid because it needs some work that i no longer have the space or equipment to do
the rear frame is going cuz my dad but way to much weight on the back,
popped a weld on the drivers side door- Small
the u joint are a bit clanky but have back ups and shafts as well
back passenger door handle does not work - very common !
working on the transfer case works fine just popped out of the bunching and has been a pine in the butt to get back in
other then that is is drive-able and drive it almost every day im asking $2500 and that is with the new wench
just dont have the time, space or equipment to fix it now
