96 Cherokee Sport 2 Door 4WD For Sale. $1250
232030 Orig. Miles. Runs & Drives Great. Must Sell ASAP.
Jeep is Located in Plano, TX. Clear & Clean AR Title.
Still has 55psi Oil Press. when Idling. Tough Ol Jeep!
If Interested:
Call or Text 479-234-0720 After 3PM Mon-Fri
& Weekends from 9-5.
Or PM me Here or E-Mail me at [email protected]
Lots of aftermarket Upgrade Parts Installed:
1) Steel Roof Racks w/ 32" LED Light Bar.
2) LED Headlights, 4"X4" LED Fog & Backup Lights
& All Exterior lights replaced w/ LED's.
3) HD Headlight Wiring Harness w/ 2 Relays.
4) Aftermarket Stereo w/ CD & USB. 5.5" Pioneer front & 5.5" Sony Rear Speakers. 2-6" Bass Cannons & 40W Amp Included.
5) Cast Iron "Solid Axle" Rear Diff. Cover
& "Steel Rough Country" Front Diff. Cage.
6) Heavy Duty Front Coils & Rear Leafs w/ Add a Leaf.
7) 2.5" Front & 3" Rear Lift (Spacers & Shackles)
8) 1.5" Sway Bar Drop Blocks (Improves Cornering)
9) Steel Diamond Plate & Cargo Area Pan Installed.
10) Full Length Passenger Side Floor Pan Installed.
Mechanical Parts Replaced in last 2 Yrs:
1) 200Amp Alternator w/ 4Ga Cables.
2) All New 4Ga Battery Cables. (Positive & Grounds)
3) New S.S. Exhaust Manifold & Gasket. (No More Exhaust Leaks!)
4) New Power Steering Pump & Serpentine Belt.
5) New High Flow Water Pump.
6)Brakes Completely Rebuilt w/ New Front Brake Calipers & Rear Drums. (New Pads, Shoes & Hardware)
(Front Rotors Replaced 5 or 6 years ago)
7) All New "Gabriel" Front & Rear Shocks.
8) Tube Lower Control Arms.
Also Have the Following Additional Parts For Sale for $250:
1) Complete Set of Lifters & Valve Keepers.
2) Valve Cover & Head Gaskets.
3) Timing Chain & Sprocket Set w/ Gasket.
4) Adj. Tube Upper Control Arms.
5) Adj. Track Bar w/ Grease Fitting.
6) New Dana Front & Rear MOPAR Pinion Seals.
7) 2"X4"X1/8" Square Tube Rock Rails Cut to Fit w/ End Caps.
8) 2.5"X1/8" Steel Flat Bar Frame Stiffeners, Cut to Fit.
9) NIB Turn Signal Switch.
10) 1/4" Hardwood Panels & Metal & Rubber Trim.
(To Replace Lower Door Panels)
Also Included w/ Jeep:
1) Large Sheet of Coyote Tan 2000 Denier Nylon Backed USMC Duffel Bag Material for Headliner.
2) Large Roll of Foil Foam Insulation for Headliner to Insulate Roof.
3) 1 Gal Epoxy Resin to Stiffen Headliner.
4) All Interior Parts & Pieces & 1/2 Gallon "Herculiner" Bedliner.
Drove this Beast for 12 Years & Now It's Time to say Goodbye!
If Interested:
UncleSarge58
That is a steal!
Jeep just SOLD about 30min. ago!
Parts Listed Below Are Still Available:
96 Jeep Cherokee Parts For Sale for $250:
Make me an Offer!
UncleSarge58
