ktm racer 419
- ROW DIALIN
here is the deal. I got too used to my 4 cyl comanche. Now that i threw 33's on my stock geared 4.0 auto 99, it has WAY more power than my 5.38 geared 96 on 35's
something is not right here.
its a 96 4.0 aw4
the power only kicks in around 4250 rpms and even then it isn't too impressive. other than that it just kinda lugs along. I can still get it up to highway speeds no problem and cruise along just fine.
new parts:
plugs
wires
cap
rotor
cps
o2
air filter
fuel filter
alternator
battree
tps,map,and iac are all good
coolant temp sensor is good
cat is fairly new (could see through it one month ago)
Hooked it up to the scanner and everything looks fine, no codes.
Not sure where to go from here.
any ideas?
its a 96 4.0 aw4
new parts:
plugs
wires
cap
rotor
cps
o2
air filter
fuel filter
alternator
battree
any ideas?
