95 cherokee 2door , no door kit?
http://www.projectxj.com/mods/doorless.htm
I used that write up on my 94 2 door
The doors worked fine for a little under a week, then I started having problems with alignment and leaking
I attribute it to the fact that the doors on 2 doors are so much heavier then those on a 4 door so just keep that in mind if its your DD...but it may have been a problem specific to my rig
we did the hinge modification on a 4-door (power locks/windows) and it was a B#(*@& to get the things back on, getting them off was cake.
but because of the weight/aligning the pins its tough. and that was a 4-door, i wouldn't try it on a 2door
I agree with the above. I did it to my MJ and I have a hard time realigning the drivers side door. I actually still have to take the upper 3 bolts loose everytime to get it back on.
