- Rainy side of Washington
free, located in southbridge, you pick em up. Will deliver for gas money.
Available: case halves (front case is still assembled, would be fine as a start for a doubler box build) front output shaft (no yoke)
I'm keeping the front yoke, rear output shaft + oil pump + tailhousing + chain, but basically everything needed for a doubler box is here. Input gear is a little rusty from sitting outside and it's had a little water in it, but there wasn't any corrosion on anything I saw, all the bearings look great, and it turned smoothly, so I'm pretty sure it will work fine. The shift shaft and gate were stuck when I got it but I cleared that up by disassembling and cleaning out the detent spring and pin a bit, it's got a little rust on the spring but nothing that couldn't be cleaned off.
