MTBracer367
- northeast pa.
So I just picked up another cherokee it's a 91 2dr 4.0/ax-15/np231. I broke a short fork in the trans and went to swap it with my spare ax-15 from a 94. I also have everything for the external slave cylinder setup. My problem is that the 94 trans has a slightly larger input shaft then The 91. I took out the 91 pilot bearing and bushing but the 94 piolet Bearing is to small for the end of the crank still. What I need to know is if there's a bearing made to fit my application And the part number for it. This is my daily driver right now and I need it fixed yesterday.
