oldcancer
- Edmonton, Alberta, Canada
i know this question probably gets asked alot, i did search but i turned up nothing....i probably used the wrong keywords lol, but in any case....
i have a 92 xj 4.0L and i also have a 94 4.0L both with an aw4 behind them....
i plan on rebuilding the 94 block and throwing that into the 92 when spring rolls around....is there anything i should be worried about or should it just be a direct swap?
thanks in advance.
EDIT: might be an NP 231 t-case, not sure about the t-case for sure but it's whatever one the command trac is (shift pattern is 2hi-4hi part time-n-4lo part time)
thanks in advance.
