jfiscus
- Middletown, OH
Ok, this question is on a 1993 Jeep Cherokee 4.0L.
I was told this XJ was running down the road & died, never to start again.
You turn the key & "nothing".
I hear the fuel pump prime & some relays click & that's it.
I jumped the positive terminal to the starter & it turned right over, still didn't start/run though. I don't have spark from the coil to the dist & the starter doesn't work from the key.
What is my problem?
Will the CPS cause the starter not to crank over?
What else will cause the XJ not to start?
My 89 XJ had a starter relay that caused similar problems, but I always had fire from the coil when starting.
What is my problem?
