1993 Jeep Cherokee
Two Door
4.0L HO
Auto (AW4)
4x4 (np231)
220k ish
This little guy runs strong and shifts nicely for the amount of miles on it. It is a project vehicle, it's about 85% finished. I drive this daily, it is currently inspected in PA until 1/13. Really the only thing needed to make this thing a fun wheeler would be to put some gears and lockers in.
Here's a link to the build thread with all the pictures of the build process.
http://www.naxja.org/forum/showthread.php?t=1051518
This is a short list of everything I did to it.
Replaced all sheet metal on the floor from the firewall back
Chopped the top off
Sealed the cab in
Built the "bed"
Relocated the fuel tank into the bed
Built a custom rear bumper/crossmember
LED tail lights
Fully Custom 6 point hybrid exo cage made from 1.75" DOM tubing with .120 wall
4 point safety harnesses tied into the cage
Rockers cut out and raised a few inches and replaced with 4x2x.125 rectangular tubing
New rockers tied into frame and cage
Frame stiffeners added from front of cab to rear of frame
Trail Gear Creeper joints added onto custom made shackle relocators
Boomerang shackles
Brand new hd stock leaf pack with an extra leaf added
Rear wheel wells relocated and rebuilt
Rear quarter panels plated with .125 thick armor
Front wheel wells cut out and modified
Battery relocated inside cab.
Brand new ZJ brake booster and master cylinder
Tj flares on all four corners
Crown Automotive extended stainless steel braided brake lines, front and rear
3in rough country coil springs up front
35x12.5x14 good year mtr
Performance header
Throttle body spacer
Brand new custom exhaust from header back, including a new cat, with performance magnaflow muffler
There's alot more than what's listed but I didn't want to make you read a novel.
In a nut shell this is an XJ sitting on 3in of lift and 35's
Also I have quite a few extra parts that go with it.
I am motivated to get rid of this and get out of the off-road world for awhile. Depending on the offer, I"ll throw in everything I still own that is related to the off-road world, which will include spare front axle shafts, Tom Woods front drive shaft, misc. front clip pieces, a small cobra cb, 60" hi lift jack and various other parts. So please shoot me a pm if you have any other questions.
Jeep is located in Erie, PA
$3800 OBO
Two Door
4.0L HO
Auto (AW4)
4x4 (np231)
220k ish
Chopped the top off
Sealed the cab in
Built the "bed"
LED tail lights
Boomerang shackles
Performance header
$3800 OBO
