comanche91
- Sweet Home Alabama
Probably a stupid question, but here goes. I have to remove my front brake calipers so I can pull the rotors and install 1/4" longer wheels studs. I am using a 1/4" spacer behind the wheel to clear the LCAs, and there are not enough threads left showing for the new wheels, only five turns until the lug nut seats. I Do I need to remove the brake pads from the caliper, or can I just unbolt the caliper and slide it off, then back on? Have not done this before. Thanks.
