edlepp
- northern b.c. canada
well i have finally got the cps bolt out of the bell housing but have a new prob. it seems like it is idling 2 low and hesitates or stalls when coming off the throttle the back on, ie: cornering, or backing out of the drive way then going forward. as this is a new jeep to me only had it 2 weeks i do not know if it did this before, but it did not seem to do it before i changed the cps. I have changed a lot of parts in this time including
cap rotor
plugs wires coil
cps
ground to dipstick and body
positive to starter
fuel and air filter
fuel pressure good 34 psi
fixed 2 vac leaks
set tps
have also traded a air idle switch thing with another xj. when i unplug it it makes no diff???
gone through my whole useless haynes manual and followed what ever procedures that fit a Renix. now I am totally stumped. I did have to pull starter and split the tranny back about half inch to get my cps bolt to drop. any help would be great.
cap rotor
plugs wires coil
cps
positive to starter
fuel and air filter
fixed 2 vac leaks
set tps
