89 2 door XJ $200.00
trickcomanche
Lemoore CA
Got an 87 2 door 2wd XJ. Its white with grey interior. It had a siezed up 2.5. Removed the 2.5 and installed 4.0 electricla harness, pcm, and motor. Ran into engine placement issues with mounts and such, and thats as far as it went. I am selling the motor, harness and pcm for aditional. If not then it will be removed. Ill take a total of $400.00 for the whle thing. Its straight, good glass and the gas shocks on the hatch still work. Located in Lemoore CA
Too bad white is bad ju ju for me.
It's still white underneath, and I dont have the patience to take it down to bare metal.
The MJ has been rolledand is just a cab and dash. There is no bed on the frame but the so called frame is there. I dont have any pics currently but its 99.9% strait body, wing window on passenger side is out. Just a 2 door white XJ.
I am definately interested, I am in Bakersfield. I am doing a gear and locker change for a guy and will have some money around the end of the month. What is the bottom line for the cherokee, and possibly the comanche too if the back of the cab is worth saving? I can give you my e-mail if you want to pm me.
