Elcapitano
- Kent, WA
From what i understand, the electric fan is supposed to turn on at 190f as well as when the A/C is going.
My A/C has never worked since i got the jeep 2 years ago. Turning the incab controls to A/C Max while running does not turn the fan on.
Cooling fan switch is brand new.
Using a Jumper lead from the battery to the fan forces it on so i know the fan is functioning. going through a couple How to's for the fan system i have located the fan relay. i am able to Jump the fan connecting points 1 and 4 on the relay. The guides are saying i should be getting a voltage read out on point 2 but while testing it i only get a positive read out on point 4.
Its getting warmer and i would like to get my fan to function correctly without having to fiddle with a toggle switch. any helpful tips are appreciated.
Thanks again!
Thanks again!
