88 cherokee tail light question
Rockken
NAXJA Member # 1674
Westminster, Co.
I have an 88 cherokee that has been chopped. I want to add tail lights and need to know a few things. There are two bulbs in each tail light, I need to know if one of the bulbs is used for the tail light and the other is for the brake/blinker, or if there is a different configuration for tail light, brake and turn signal. I also need to know which side of the dash the wiring for the tail lights is on. All the original wiring to the back has been stripped out.
Thanks
There are 3 bulbs in my 95. Brake, Tailight, Reverse. But, I have housings from a 88 Waggy on it that had 4 bulbs?!!? I just switched the bulbs out. So I'm guessing older models used a seperate light for the brake and blinker, but newer pre 97s have a dual blinker and brake. I would just tie the wiring in together on the bulb if 88 Cherokee tails have 4 bulbs like Waggy lights do.
