moparPW200guy
- Seattle, Wa
ok upon startup my 87 cherokee laredo pulls somewhere around 2-3000 rpm. i have a new TPS that i need to put in but what else should i do to help that?? also how should i go about adjusting the TPS? what else could be causing this problem??? also my temp guage does not seem to work. i have replaced the sensor, new radiator, new thermostat, new housing, new fan switch, new overflow bottle x2, and a new upper hose. it just reads right around 100* when warm and below that when cold. any ideas???? should i just put in a mechanical guage in place of the factory unit??
also the tranny seams to be slipping just a touch... i know it needs to be serviced but i have never done this befor on my own. i have always had a shop deal with those types of things. i know i will need a gasket and filter for the pan BUT is there anything else i will need besides trans fluid?? also what type of fluid should i run??? i know i am asking alot in my first post but i am going to be bringin the XJ home within the next 3 days so i need to know like SOON!
thanx for listening to my little rant here and thank you for you help in these matters..
