87 Cherokee 4x4 4door.
jeeptec
87 Cherokee 4x4 . 4dr. 4.0 aw4 automatic.211k on odo. Note both engine and trans have been replaced with reman units.6.5 long arm suspension. Teraflex arms converted to radius style. 6.5 Rusty's front springs,shocks ,steering box brace,track bar brace. Has over the knuckle high steer using Rusty's, go for parts. 93 non disconnect front axle with all 93 axles,hubs and brakes. Front axle housing has been sleeved with synergy suspension tubes. Also has axle brace from housing to right upper control arm mount. Lower knuckle braces.. 4.56 gears open in front. rear axle is Dana 44. 4.56 also. Ected electric locker. Stock axles. Teraflex rear disc brakes and matching parking brake cables.Rusty's 4.5 rear springs with 1.75 shackles. Rancho rear shocks. Advance adapter HD short shaft kit. 93 grand Cherokee drive line installed in rear. Has 60mm throttle body and spacer. Uses later style std thread oil filter. HD alum radiator converted to 91 style cooling system. Has by pass switch for fan. Head lights have been relay wired for more output. Sandstone yellow exterior color. Has some off roaring body damage. Custom front bumper has mount for winch. Custom rear bumper will mount high lift style lack. Rock sliders. Quarter guards but are damaged. Hounds tooth tan interior. Drivers seat is worm but interior is in good condition for age of jeep. Stereo. Registered. . will smog at time of sale. 33/12.50/15 good year duratrac tires about 50% procomp black rims.. This has been thought John bull, Holcomb creak and many other trails. I'm asking 4000.00. Pvt for more details.
