CartsXJ
- Glenville, NY
Finally tore down the old 8.25 and here is a list of parts that are up for sale.
-Bluetorch diff cover - $50 ($75 repainted any color you want)
-2 - 29 spline shafts with C-clips - $50 each
-29 spline factory trac-lock, was rebuilt two years ago - $50
-Factory 8.25 pinion 1310 size u-joints - $25
-ZJ disc brakes, backing plates already opened up for an 8.25. E-brake cable to work with a late model and calipers, explorer soft lines that I can imagine you could make work. Those if you grab ZJ softlines these bolt right up. Will fit any late model XJ, TJ, ZJ rear. Could use new rotors, pads and ebrake pads. - $150
Will consider offers on any of it
