60deg-90deg gm v6 adapter
mike86xj
I'm looking for a bellhousing adapter to stick a 4.3 v6 into my 2.8 ax5 equipped jeep.
I know the trans is a pos but I dont want to change it, just making the jeep last another year then I'm buying a newer one
Or if anyone knows where i can find a 3.4v6 from a 93-95 camaro or firebird for cheap that'll do too
if someone has or finds a engine, remember i'm in manitoba canada so i would prefer it to be closer to me. minnisota north dakota would be good maybe a little further if cheap enough
thanks
Mike
5-90 said:
Can't help you on the engine, but have you checked Advance Adapters or Novak Conversions for the adapter yet? Google should turn either up fairly quickly - I don't recall the URL's offhand.
5-90
EDIT - Almost forgot! When crawling the boneyards, don't neglect the FWD cars you see. Check the back side of the block for a second starter mounting pad - the "Goodwrench Service Replacement Engines" had starter pads on both sides, so they could be use FWD or RWD/4WD. Just another thought...
I cant justify spending $3-400 on an adapter when i could get a 3.4 for a little more than that locally.
I was hoping somebody has a used one that they dont need anymore.
advance adapters wants $455.40
novak does not carry one most likley because the ax5 is a pos
but thanks for the fwd motor idea, I had no idea they did that the replacment motors were set up for either front or rear wheel drive.
thanks Mike
:cheers: :cheers: :cheers: :cheers:
