mikeNtucson
- Tucson, Az
If I do hp44 front, how do i get rear 5 on 4.5 to match front? Can I do disc brake conversion?
Cruzin Illusion said:I run 5x5.5 on my rear XJ44. I am also running a HP44 up front that I shortened to a waggy width. I am running 33 splines shafts in the rear but shouldn't matter if you buy aftermarket chromoly shafts they should have a dual drill pattern for 4x5.5 and 5x5.5. You will need to drill your drums or rotors for the 5x5.5. Depending on your skill level you can do this by yourself or get a machine shop to drill them for you. I drilled the 5x5.5 pattern myself and have had no problems. If you have any questions you can PM me and I will help you out.
mikeNtucson said:Yes the front is wider, no I don't want a 9" rear. I quess I stick with stock crap.
