POSJ
- Minot ND, Unfortunately
Ok I already searched, closest I came was this thread: http://www.naxja.org/forum/showthread.php?t=98173&highlight=4x4%2A
I am having a problem with my 4x4 enaging...it doesn't. High or Low. I pull the lever back and into High and I can feel it pop into place, every once in awhile when I try it I hear gears grind for a second and I pop it back out and I amd it's fine. 4x4 works every so often in reverse but not at all in drive. I have no disconnect in the front it has washers and spacers to hold the sleeve over both axles. Any advice would be appreciated. I'm thinking I need a new T-Case at this point.
Tyler
*Edit*
This began when giving it gas and the 4wd would pop out under load. Like the above post was saying, but he never got his worked out and the thread died.
Tyler
*Edit*
