OutkastBoss
- Saint louis
first off its a Late Model Np231 With electric Switch
OK so I Swapped in a used built T-Case and it works great but no shift light.
So after searching here I pulled the plug on the switch and jumped the connections and the light came on So Bulbs good.
So I ordered and installed a new switch And it works but only right as i shift it in to 4wd and if I Pull Back a bit on the shift lever it will stay on until i let go.
From my searching im thinking this means it the shift linkage needing to be adjusted .
Is there anything else it could even possibly be, like something internal of the Tcase that would need adjusted ?
