Does anybody running a stroker engine with mopar perfomance Camshaft DCC-4529228AB (Advertised Duration 240/ 240, Lift .430/ .430) work fine?
im not sure to use it in my storker...
my storker is in base of:
4.2 Cranck
4.2 Con-rods
4.0 Pistons (.3)
Mopar Camshaft or Stock (i take my choice considering your recommendations)
4.0 Valve Springs
4.0 H.O (1995) Head
4.0 H.O (1995) Block
External Fuel Pressure Regulator
62MM TB
D. Thorley Headers
FIPK K&N
Ford 24 Lbs Injectors
8mm Wires
now, as you can see the only doubt is the camshaft¡¡¡¡
Juan Pablo
Chile
south America
4.2 Cranck
4.2 Con-rods
4.0 Pistons (.3)
4.0 Valve Springs
4.0 H.O (1995) Head
62MM TB
D. Thorley Headers
FIPK K&N
8mm Wires
Juan Pablo
Chile
south America
