kyle_cantwell
- youngstown ohio
so i just did the rubicon express 4.5 lift with the stainless steel hoses. i also had to run a new main hard line to the back due to it looked like it was sitting at a salt factory. i bleed the breaks 10 different times i bled the master cylinder fluid goin through all the lines with no air bubbles the break booster vacuum is also working. my question is when the jeep is off n you pump the breaks the pedal gets hard.. when you turn it on and try to use the breaks it goes straight to the floor and there is no pumping.. has anyone had this problem?!?! Please :helpme::helpme::helpme:
