Jeff in VA
<---respect
- Richmond, VA
Pulled a wiring harness off an 88 4.0/AW4 MJ in the ‘yard today, and have a couple of connectors I need to identify. The MJ had been picked over a bit before I got there and some stuff was missing….I’ve got everything figured out except three connectors to the manifold/TB area, and two connectors under the manifold, in the same loom as the knock sensor.
First, the three on top of the manifold. One is a 4-wire connector:
Blue/yellow tracer
Green/black tracer
Purple/black tracer
Red/yellow tracer
One is a 3-wire flat connector:
Yellow/green tracer
Brown/white tracer
Red/yellow tracer
And one is a 3-wire square connector:
Light gray/black tracer
Red/no tracer
Tan/pink tracer
The others are below the manifold, in the same loom as the knock sensor:
2-wire connector:
Tan
Brown/white tracer
3-wire connector (is this the O2 sensor connector?):
Orange
Gray
Black
BTW....here's the whole mess. Took me about 2 hours to pull it all (once I figured out how to get it seperated and pulled thru the front clip Got the whole harness, radiator support, fan shroud, ECU, throttle cable and linkage for $50......
Blue/yellow tracer
Green/black tracer
Purple/black tracer
Red/yellow tracer
Yellow/green tracer
Brown/white tracer
Red/yellow tracer
Red/no tracer
Tan/pink tracer
2-wire connector:
Tan
Brown/white tracer
Orange
Gray
Black
