350 conversion
dacerdude
dallas tx
has anyone done this conversion or considered it
i have an 1985 jeep pioneer 4x4 manuel tranny
i need tips on what all i need to do
Things i know:
i need new motor mounts
need to replace adn move the radiator
need either to pull full powertrain off old chevy or get conversion plates(IDEAS ON WHICH ONE ANYONE)
3 inches of lift minimum
IF ANYTHING IS MISSING PLEASE FEEL FREE TO INFORM ME
Things ppl are telling me not sure:
ppl have been telling em that i need to reinforce the frame and i shouldnt do it b/c its a waste of money b/c i will be pretty much changing everythingn on it except the body(INPUT ON THIS TO PLEASE)
THanks guys
Dace
Give advance adaptors a call. They have the motor mounts I know I have planning this for awhile myself Just bought the donor vehicl sunday so maybe this winter I will do mine. I was told that Advance adaptors also has a booklet to include other information (vague I am sure) on the swap good luck and let me know how it turns out.
Things i know:
THanks guys
Dace
I have been running a chevy 350 in my 89 XJ for almost a year now. As xjfanatc mentioned, Advanced Adapters makes most of what you need. Feel free to PM me if you have any questions. On your list I will give you a heads up: drive drain is an AX15 but the shaft is replaced with a heavier duty large tooth spline where it meets the clutch (used on dodge dakotas), bellhousing from Advanced, both drivelines are different lengths because the 350 site further back than the 4.0, 3 inch lift is tight (i was on 3 inches and moved up to 4.5 for better clearance on steering components). I could ramble on but I have not had any problems other than with my wallet. Feel free to PM me if you have any questions.
Things i know:
THanks guys
Dace
AFAIK it should drop right in.
Now you can run duals.
:moon:
