BPB NAXJA Forum User Location Battle Ground, Washington Apr 9, 2008 #1 are the splines on the output for a 2wd mj the same as a 4wd mj?
IslanderOffRoad NAXJA Forum User NAXJA Member Location Houston, Tx Apr 9, 2008 #2 i'm not sure about the spline count but you can bet the length is very different.
BPB NAXJA Forum User Location Battle Ground, Washington Apr 9, 2008 #3 that is the point shortening a drive shaft is way cheaper than lengthening one.
M MiNi Beast NAXJA Forum User Location Fruitport, MI Apr 9, 2008 #4 What trannys are the yoke coming from? yoke has 26 splines for a 231.
Jeff in VA <---respect Location Richmond, VA Apr 9, 2008 #5 No, they are different. You can use the shaft, but you have to replace the slip yoke with a 4WD version. Jeff
