2003 WJ/XJ 4.0 for sale fits XJ $400 160k
markaboo929
Mooresville,NC
I have a 2003 WJ 4.0 engine with about 160k on it.I have drilled and taped the bare spots on the block to fit the xj acessories,I have been in the auto repair for 25+ years so no worries on drill and tap.I have installed my 4.6 stroker and it has survied the 5000 mile mark!! That was the reason I was holding on to it so it has to go now.It was in my 1988 Renix XJ bolted to an NV3550.It runs excellent no noise (gaurantee it) and I have used 4 oz of lucus cam breakin lube per oil change to get the zddp it needs,with mobil 1 high mileage 10w30 which has more than usual oil zddp content...look it up.Anyways it will fit all Jeep 4.0 applications...XJ/ZJ/WJ/YJ/TJ using the 4.0.I got the engine with 10k documented miles on it...WJ totaled out.The flywheel is not on there or the T-body I do have a stock 2000 flywheel for it though if you need that and a stock T-body from a 98 motor.It has a stock exhaust manifold from a 98 bolted to it and yellow bosch 19# injectors,WITH the clips (Volvo-same as Ford) ---no dual cat.$400 and located in Mooresville,NC.I still have a crane I was borrowing so it can easily be put in/on truck trailer.I am going to put it on craigslist,but wanted to post here first.I will post up pics later...I am not home at the moment.Thanx
