ChopandChange
- Tennesee
New here and really needing some help. 2001 XJ Limited, 3in RC suspension lift, 31" Grabber AT2s. Nothing fancy.
Transmission is not wanting to engage in D. 1-2, 3, and R all good, manual shifting is fine, you can feel the acceleration is normal. Put it in drive and the engine revs normally but no forward progress. If you pop into D while going around 35+, response and shifting is normal.
What I have done:
-Full trans flush, level is good.
-Changed all shift solenoids
What I haven't tried:
-Checked TCU fuse (can't find the bastard, seems easy when everyone else shows it)
-Swapped the TCU
I've been through all the threads related, but they all seem to have some different factor that makes them not directly relevant.
Thanks
What I have done:
-Swapped the TCU
Thanks
