SChiaradonna
- Blackwood NJ
Hey guys just recently purchased a 2001 cherokee sport. Not new to the jeep world by any means but I got my hands full with this problem and its starting to drive me nuts! Any way the jeeps giving me a problem starting. Goes through about 4 cycles before it finally turns over and after sitting off for 3-5 minutes has the same problem. At first thought it was the fuel pump because it wasn't holding pressure so replaced the whole assembly, then from there replaced the cam and crank sensor because they seemed to be common problems. (Crank sensor is a pain by the way ahaha) After that didn't do the trick I decided to finally run a computer on it and saw I had a cylinder 2 misfire so I changed the plugs and ran a leak down test and sure enough it was leaking down in the injectors, so I replaced the injector on cylinder 2. Now I am stuck because it is still giving me this problem and I feel just helpless and don't wanna just keep throwing money at. Hoping for some helpful answers. Thanks. Sal.
