jbeintherockies
- Aurora, Colorado
Hello,
I was informed this morning that my brake lights are not working (including the center-high brake light).
The hazards work, the blinkers work, the reverse lights work and the tail lights work when I turn on the parking lights and headlights.
I will start to check fuses and use a volt meter to see what the issue is. I have read there is a switch above the brake pedal (how old school!). But, I have been at work all day (just got home) and haven't had a chance to climb under there to see if there is a contact issue, or to check the voltage on the switch, check fuses, etc.
Any suggestions? Anyone else have issues with brake lights not working? How did you fix it?
I'll do some google searches and see what I can find on here.
Thank you in advance.
