jeeptec
- atascadero california
2000 XJ. 4.0' automatic. 231 tfc. Dana 30/8 1/4. 183k. Clean title current registration til Sept 17. Siege color. Charcoal interior. Good body clear coat is flacked off. Lower rear 1/4 guards. Rustys off road sliders. Warn transformer brush guard with winch plate and REW 9000 winch( mile marker copy). Winch has been wired to operated with winch control and a toggle switch on dash. Rear bumper is bent. Factory tow hitch and factory tow package with H.D cooling and aux trans cooler. New radiator installed over the summer. K/N cold air intake.magna-flow muffler.4 hole upgrade injectors.stock AW4 automatic. 231 tfc with Advance adapters slip yoke eliminator kit( originally a 242 vehicle) Tom woods drive shafts front and rear. Rusty's heavy duty trans cross member and factory transfer case skid plate. Tompkins gas tank skid plate. 8 1/4 rear diff 29 spline 4.10 gears with Aussie locker. 95 Grand Cherokee rear disc conversion with parking brake.Pro comp 3.5 rear leaf springs with 1.5 shackles for 5 inch lift. Bilstien shocks front and rear.braided brake lines front and rear. Front low pinion Dana 30. 4.10 gears with True track limited slip. Stock axles. Power stop front brakes.steering box brace. Y link steering with Rustys heavy duty adjuster sleeve. Left tie rod flipped above knuckle. JKS sway bar disconnects. Synergy track bar with frame drop bracket and frame brace with matching pitman arm.Synergy JK 4.5 front springs net 3 3/4 plus daystar 1 3/4 spacer nets almost 5 inch lift with weight of winch. Synergy lower control arms with Rock Road drop brackets with frame braces. Supreme suspension upper adjustable control arms. Front diff guard. Hercules Trail Digger M/T 285/75/16 tires 90% tread left. TJ Rubicon rims with Synergy 1.25 hub centric spares. Charcoal grey interior. 1 cigarette burn on rear seat from a previous owner. Wear on the side of driver seats not on the seating part. Head liner just starting to come down over driver. Interior in good condition other than mentioned. Upper console. Lower console. Pinoneer radio. Cb radio.power windows power locks all working. Roof rack. Working A/C . Asking 6000.00 or trade for a 68 to 71 Dodge Dart,Demon or Plymouth Duster. Note I will be in Ontario For training on the 12 and 13 th of January I may drive down with XJ to up to Big Bear depending on weather.
Sent from my iPad using Tapatalk
