Renegade360
- SW FL
Thought I'd share some info on my upgrades.
Stats
99 XJ
OME Light weight leaf springs from DPG.
Front RE 1 3/4" Coil Spacers
Front Bilstein 5100 shocks.
Rear Stock Shocks (need to replace)
Distance from stock fender flairs to hub center
Before Lift Front 17 1/2"
Rear 16 1/2"
After Lift Front 19 3/8" (1 7/8" net Lift including new stock isolator)
Rear 18 1/2" (2" net lift after install over 3 months ago)
AJ's Rock Rails
I have not trimed anything yet. I can see that I may need to in the rear, see second photo. I'm not sure If I'll have to trim anything in the front.
Tires are goodyear Duratrac 245/75/16
They replaced 235/75/15 on stock steel rims. I never had any rubbing issues with these before or after lift.
Stats
99 XJ
Rear 16 1/2"
AJ's Rock Rails
