ColoradoRaptor
Headbanging Hillbilly
- Canon City, Crawlorado
Anyone here runnin 2 batteries mounted in the cargo area? If so pics please. Ideas are welcome aswell. Thanks!!::
bandit455 said:DO NOT USE OPTIMA'S INSIDE!!!
optimas are gell cells and still emit gasses!!
the only battery actually recommended for interior use is oddesey batteries.
they are solid cells and emit no gasses. they are also much smaller in size which will be great for your application.
BlueCuda said:You might be able to stack them in the far back passenger side corner. .
mk153smaw said:well if you are lifted high, you could fab some extended boxes that drop a little lower from under the seats just for the batteries.
ColoradoRaptor said:Very good idea!! I will look into that!!:thumbup:
BlueCuda said:Here is some ideas for what batteries to use.
If you want one
http://www.interstatebatteries.com/estore/search.asp?details=1&mscssid=7TNFW4CF338P8HBU49VW6FUG2U2R3RLA&Ntt=31P%2DMHD&N=0&Dx=mode+matchboolean&part_number=31P%2DMHD&Nty=0&D=31P%2DMHD&Nu=Part+Number&Ntx=mode+matchboolean&part_desc=Light+Truck%2FVan+Mega%2DTron+%2D+950+CCA&Ns=product+Type%7C0%7C%7CRank%7C1&Ntk=SearchGroup&js=1
If you want 2
http://www.interstatebatteries.com/estore/search.asp?details=1&mscssid=7TNFW4CF338P8HBU49VW6FUG2U2R3RLA&Ntt=MTP%2D91&N=0&Dx=mode+matchboolean&part_number=MTP%2D91&Nty=0&D=MTP%2D91&Nu=Part+Number&Ntx=mode+matchboolean&part_desc=Mega%2DTron+Plus+%2D+85+Months+%2D+700+CCA&Ns=product+Type%7C0%7C%7CRank%7C1&Ntk=SearchGroup&js=1
