11k DELIVERED....EVEN TO WEST COAST, YOU COVER TRAILER COST, I'LL COVER GAS. CLEAN TITLE IN HAND. Will consider trade for sports bike, newer Harley, plus cash or H&K pistols or rifles. LET ME KNOW WHAT YOU'VE GOT!!!
I am selling my fully customized 1999 Jeep Cherokee Sport. I am moving to a place where I cannot take it so it is for sale. It has been built for rock crawling and has been used for daily driving use as well as competitions and general trail use. It has a current VA State inspection and licensed for road use. VERY custom set up and is a blast to drive! This Jeep will take you ANYWHERE and will do so in style! I will be selling the Jeep for cash but will entertain trade of a motorcycle plus cash.
For reference, it is currently in Quantico, VA. You can call Nick at 804-651-1826 if you have any other questions.
Details on the Jeep are as listed below.
-1999 Jeep Cherokee, Black
-4.0L, Straight Six, 149,000 miles
-AW-4 automatic transmission
-NP 231 Transfercase with Advance Adapters SYE
-Carolina Driveline double cardian rear drive shaft
-Custom Full Float Dana 44 Rear end, TNT Customs Truss, 6x5.5 Bolt Pattern, Solid Axle HD differential cover, Dutchman Chromoly Full Float axle shafts, Warn 30 Spline drive flanges, ARB Air Locker, 4.88 gears, disc brakes with e-brakes.
-Custom Dana 44 front axle, High Pinion, TNT Customs Truss, 6x5.5 bolt pattern, Solid Axle HD differential cover, Alloy USA 4340 Chromoly inner and outer shafts, Longfield U-joints, Reid Racing HD knuckles with high steer arms, set up for full hydro steering with ram guard and suckdown winch tab, ARB Air Locker, 4.88 gears, Howe Racing dual piston front calipers.
-Dodge 2500 Master Cylinder
-Doug Thorley Stainless Steel, Ceramic coated header
-Custom exhaust with high flow CAT and Flowmaster muffler
-PSC Motorsports full hydro steering, Doubled ended 2.5" x 8" stroke ram, PSC pump, PSC large resevoir, cooler, high quality fittings and lines, orbital valve fitted to give 3.5 turns lock to lock.
-Grant Steering Wheel with Grant steering wheel quick disconnect
-Alcan rear 5" leafs, Full Traction boomerang shackles
-Custom rear shackle box
-King 2.5x14" coilovers with external resevoirs custom sunk into the fenders, 250/300 springs, custom front frame truss and cross engine bracing
-TMR front frame stiffeners
-TNT Customs mid frame stiffeners
-TNT Y-link radius arm suspension with HD, high clearance belly pan
-Optima yellow top battery
-Rigid Co front and rear bumpers, front modified to accept competition style winches
-Custom narrowed Warn 8,000 lb winch with synthetic line
-LeBaron Hood Vents
-37x12.50x16 Maxxis Creepy Crawlers with full size matching spare
-KMC XD 16x8 Aluminum Wheels
-THOR side panel guards
-LED Brake lights and turn signals
-Currie Anti-Rock front sway bar
-Bilstein Rear shocks
-Removable front doors
Feel Free to call Nick at 804-651-1826 if you have any questions.
-LeBaron Hood Vents
