1999-2001 Jeep Cherokee Front Wheel Bearing & Hub Assembly for Models with Full Cast
1ATony
pepperell MA
VISIT US HERE FOR GREAT PRICES 1999-2001 Jeep Cherokee Front Wheel Bearing & Hub Assembly for Models with Full Cast Rotors Pair
FREE SHIPPING IN THE LOWER 48 STATES!!!
Specifications:
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side) FRONT
3 Bolt Flanges
Fit 5 Lug Wheels
Replaces dealer part numbers: 5016458, 5016458AA, 53007449AC
New wheel studs installed
Direct replacements
Built to strict quality control standards
For models that came equipped with Cast Rotors only
Overall rotor height of 3-1/16" and 2-1/8" rotor hat height
Note: If you have any questions about this fitting your application, please call your local Chrysler Jeep dealer with the above part number.
Quality
You will not have a problem with our product. If you are comparing us to someone selling a brand name product remember brand names are only as good as the company selling them. Both Bizrate.com and The Better Business Bureau recognize 1A Auto as a trusted online seller. You will be pleased with what you find out about us.
You don't want to be delayed by a defective part. 1A Auto wheel hubs & bearings are all tested prior to shipping.
Fit Guaranteed
These hub & bearing sets will install just as your originals do. You can use your existing hardware.
Save time and money with direct fit hub bearing assemblies. No trips to the auto parts store or extra time trying to match up and press bearings.
Hub installation is a degree more difficult than changing a tire on most vehicles.
Value
Some shops and dealers charge more for parts and repairs when they think the customer doesn't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly part or repair bill.
2 Year Warranty
This item is backed by a 2 Year Manufacturers Warranty. In the event this item should fail during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
Reference #: 513158 x2
Re: 1999-2001 Jeep Cherokee Front Wheel Bearing & Hub Assembly for Models with Full C
thats a deal! and they have the same warranty as the timken units!
i just paid twice that much for a set of timkens for my WJ swap
Thank you for checking us out.
Tony
hey Tony, are these available as a 2wd hub with the dummy shaft in the bearing already?
This is definitely a good price for 2 hubs. Will be looking into them here soon.
Can someone explain the " cast rotors " for me. These look the same as any d30 wheel bearing. I have a 2001 XJ and was looking at this as a possibility.
The cast rotors should be solid, the composite rotors will have like a vented section between the flat rotor surface.
If you're not sure, you can have the dealer run your VIN. and they'll tell you what type your Jeep came with.
Tony
Cast rotors can be vented too, and XJ cast rotors are.
The difference is in the unit bearing mounting to wheel mounting face offset - 1999.5 and later XJs use the later style bearing and rotor, 1999.0 and earlier (down to some odd year splits in the early 90s depending on 4x4 vs RWD, let me know if you want info on that) ones use a composite rotor with the friction surface cast onto a pressed steel mounting "hat". The two rotors have different hat heights, and thus require different unit bearings.
A 2001 SHOULD have the later style, but you should check before ordering just in case someone has installed older unit bearings and rotors, since they will bolt right on.
Thats what I was thinking. I was thinking the difference would be some aftermarket(like performance) rotors that may be different from stock. I will check tomorrow, I am gonna need wheel bearings soon!
is your warranty voided by race applications? ;)
Same as Timken HA597449 or SKF BR930218? Anyone used these for the WJ swap?
We discussed it but they never answered my question, so stuck to timken.
