1998 SE XJ
mudderx
Spanaway, WA
1998 SE XJ
CONTACT @ [email protected]
LOCATED IN SPANAWAY WA 98387
98 JEEP CHEROKEE SE
4.0 L
195000 MILES
$3500 OBO
2ND OWNER SINCE 2002 AND 35000 MILES
PASSED EMISSIONS ON 2/5/2016.
FRONT:
4.5" LIFT COILS
DANA 30 (3.55S) WITH AUSSIE LOCKER, DRILLED/SLOTTED ROTORS, ALLOY USA TUBE SEALS, RUBICON EXPRESS RE1660 CHROMO TRACK BAR AND BRACKET, RUBICON EXPRESS CHROMO TIE ROD, SWAY BAR DELETE, NEWER MOOG DRAG LINK, NEWER MOOG UPPER CONTROL ARM BUSHINGS, IRON MAN 4X4 ADJUSTABLE UPPER AND LOWER CONTROL ARMS, IRON ROCK OFF ROAD 1/4" THICK LOWER CONTROL ARM MOUNTS WITH SKIDS, DAYSTAR FRONT EXTENDED BUMPSTOPS, CUT & ROLLED FENDERS
REAR:
3" BASTARD PACK (ITS BEEN IN FOR YEARS AND DOES NOT SAG, I TOOK OUT TWO LEAVES AND ADDED A CHEROKEE LONG ADD A LEAF AND A RANGER SHORT ADD A LEAF)
1.5" EXTENDED SHACKLES
2001 CHRYSLER 8.25 (3.55S) 29 SPLINE WITH POWERTRAX NO SLIP LOCKER
OTHER:
285/75/16S (33S) LOAD RANGE E GOODYEAR MTRS @ 20% TREAD ON BLACK ROCK STEEL WHEELS
HOMEBREW 3/8" THICK WINCH BUMPER WITH RUGGED RIDGE 8500# WINCH, 20K SNATCH BLOCK, AND 2 D RINGS
DETOURS USA A PILLAR MOUNTS AND RIGID DUALLYS
HOMEBREW BOLT IN INTERIOR STORAGE RACK, INCLUDES A CUT DOWN 60" HI LIFT (ABOUT 54" NOW) AND SPARE OLD STYLE 33" MTR @90% ON STOCK JEEP WHEEL
COBRA CB WITH WEATHER AND FIRESTICK ANTENNA
ROCK SLIDERS
5 SPEED TRANSMISSION CROSS MEMBER TO LOWER T CASE WITHOUT LOOSING GROUND CLEARANCE
IRON MAN 4X4 FAB POLY MOTOR MOUNTS
QUARTER PANEL ARMOR
UHAUL TOW HITCH AND 4 WAY PLUG WITH HITCH MOUNT D RING
PRE 97 REAR BUMPER WITH SOME LED BACK UP LIGHTS WIRED TO BACK UP LIGHTS AND SWITCH
NEW WINDSHIELD
ABS DELETE (CAN BE REINSTALLED BUT YOU WOULD NEED AN ABS D35)
NEWER RADIATOR, WATER PUMP, HOSES
NEWER EXHAUST MANIFOLD, INTAKE & EXHAUST GASKETS
NEWER ALTERNATOR
NEWER STARTER
NEWER NEUTRAL SAFETY SWITCH
SPECTER COWL INDUCTION/SNORKEL
FACTORY GAS TANK, & T CASE SKIDS
MISMATCHED INTERIOR PARTS (FRONT SEATS WERE BAD AND GOT NEW GRAY SEATS, ALSO HAVE NICE MATCHING BACK SEATS, BACK DOOR PANALS ARE GRAY BUT HAVE OLD ONES TO SWAP JUST NEVER HAVE)
AC DOESN'T WORK (GOOD FOR ON BOARD AIR)
BED LINED INTERIOR
I DO NOT HAVE THE RACK ANYMORE. THIS IS A TURN KEY WHEELER AND DAILY DRIVER IF YOU CAN AFFORD THE GAS. PRETTY MUCH EVERY BODY PANEL IS DENTED INCLUDING THE ROOF BUT HEY, CHICS DIG BODY DAMAGE
